Now tighten the top closest inside the engine bay. Again make sure your positioning is good. Look for things like the screw itself wont be rubbing against the drive shafte (it squeals if it does) once the suspensions squishes back up.
Now tightent the one that conects the pipe to the intercooler . Again, once your happy with the positioning tighten them all with a 7mm socket.
Lift it up into position and install the 10mm nut and rubber piece that holds it ull up into place and voila.
